AutoCAD Forum
Difference between STARTUP (System Variable) Values 2 and 3?
5 REPLIES 5
tempogempo
1843 Views, 5 Replies
I'm not new to AutoCad but have a question?
What is the difference between STARTUP (System Variable) Values 2 and three ... I'm confused .. is there an example to apply?
.. Thanks very much
5 REPLIES 5
pendean
in reply to: tempogempo
3 preloads the Ribbon. 2 doesn't, just has the tab
tempogempo
in reply to: pendean
I tested it too many Times .. change from startup system variable value 3  to 2 and vise versa  ... but noticed no difference happened !!
so my new question is when i should set startup system variable value to 2 and when set to 3 ?
pendean
Why are you so focused on this tiny quirk? There is no gain/benefit to either 2 or 3, it's a pointless choice from what anyone can tell.
IMHO your REAL and true choices are: should STARTUP be 0, 1, or 2/3
In both settings you land in the New Tab ribbon, the difference is when you click onto the "Start Drawing" field:
with setting 3 ... the default template is used for the new drawing
with setting 2 ... clicking "Start Drawing" brings you to a dialog where you can select the layout to use.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks a Lot
You gave me the key to solve the mystery
     >> with setting 3 ... the default template is used for the new drawing
The Red Words was the key ... I found I had no default template, so, after adding a default template from (Options-Files-Template Settings-Default Template File Name For QNEW), it put things right ...
thanks again ...
”Boost
