AutoCAD Forum
DGNPURGE Won't work on this DWG
9 REPLIES 9
Message 1 of 10
2808 Views, 9 Replies
Hello ACAD Community,
I can't "DGNPURGE" this drawing because of the following pop up error log when using the command on the drawing I linked since I cannot upload a file more than 5 mb.  I already used "AUDIT" and "PURGE" but "DGNPURGE" won't work.
https://www.dropbox.com/s/q9m6c7dve57ell6/201411-x-base-elev.DWG?dl=0
Any assistance to resolve this issue will be great thank you so much.
Rexman Ng  Associate Architect
                Baron Design and Associates
                1855 S. Ingram Mill Road, Ste. 201
                Springfield, Missouri 65804
                Ph. 417-877-9800
                Fx. 417-877-9802
                rng@baron-design.com
"See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eNullObjectId
at Autodesk.AutoCAD.DatabaseServices.OpenCloseTransaction.GetObject(ObjectId id, OpenMode mode, Boolean openErased, Boolean forceOpenOnLockedLayer)
at Autodesk.AutoCAD.DatabaseServices.OpenCloseTransaction.GetObject(ObjectId id, OpenMode mode)
at DgnPurger.Commands.PurgeLinetypesReferencedNotByAnonBlocks(Database db, Transaction tr, ObjectIdCollection ids)
at DgnPurger.Commands.PurgeDgnLinetypes()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 19.1.0.0
Win32 Version: 19.1.108.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcdbMgd.DLL
System
Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 4.0.19.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AdApplicationFrame.DLL
AdWindows
Assembly Version: 4.0.36.100
Win32 Version: 4.0.36.100
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AdWindows.DLL
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/accoremgd.DLL
" etc etc etc etc etc
9 REPLIES 9
Message 2 of 10
Alfred.NESWADBA
please find attached the cleaned drawing, did it with plain AutoCAD 2015.
I have no idea at least what happened with the tool in your 2014.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 10
in reply to: Alfred.NESWADBA
Thanks so much Alfred for fixing the file!
But how do I make sure this error log doesn't happen again? Because there are other files I try to DGNPURGE and it pops a similar error log ><
Message 4 of 10
Alfred.NESWADBA
Don't import content that has such linetypes (mostly files with high filesize, but only less content).
May be your AutoCAD does not run on the latest servicepack? >>>click<<<
And if you have a subscription then you can install AutoCAD 2015, even if you like to work on 2014. Use 2015 to clean up the file and continue to draw/work in 2014.
- alfred -
Alfred NESWADBA
Message 5 of 10
ALFRED, HOW DO YOU DGN PURGE WITH 2015?
Message 6 of 10
Alfred.NESWADBA
Just run purge and use the new option for "Automatically purge orphaned data"
- alfred -
Alfred NESWADBA
Message 7 of 10
THANKS ^5
Message 8 of 10
nestly2
Purging DGN data is easier in 2015 because of the enhanced PURGE option, but the result is the same using the DGN hotfix in 2014.
Below is DGNPURGE from within 2014 on the attached file.  (it went from 10MB to 373KB) just by using DGNPURGE to free up the DGN data, then PURGE > Linetypes to get rid of the previously orphaned Linetypes )
PS,  I initally had trouble getting DGNPURGE to Netload.  I had to go into both of the files after I had moved them into my 2014 directory and allow "Full control" to my current Windows profile.
Message 9 of 10
in reply to: nestly2
Wow what a PRO.
Thanks Alfred and Nestly!
Although here at our office we currently do not own a license to the 2015 AutoCAD version so we are using the hotfix on our 2014 versions of AutoCAD.
Thank you much for the fix and the video is very nice, how did you make a gif out of the screen? Very nice!
Message 10 of 10
nestly2
I use Camtasia Studio to capture the screen video then convert to an animated gif, but a couple of free alternatives are Autodesk's Screencast (formerly known as Chronicle) and Jing.  You can use both to capture video of your screen and both offer free hosting of the videos.
”Boost
