I'm currently working with Autodesk 2013. I tried to generate drawing views, section views and detail views from model space. Actually this tools reduce many time and increase productivity very much.
I want to know that is there any possibility to generate detail veiws with dimension or should I add dimension manually?
The dimensions will have to be added manually.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
