Problem:
I've created some drawing views of a model with detail views showing some specific areas of interest. - I have one user who when they select the detail view callout gets red grips on it instead of the blue ones I get. - When they move the detail callout, the detail view does not update to show the geometry of the new location. - When I move the detail callout the detail updates to show the newly highlighted area's geometry.
We both are using AutoCAD 2014.
VIEWUPDATEAUTO is set to 1 on both machines.
What could be the matter?
Chuck Ross
Hi Chuck,
Can you post a video of this behavior to sure we fully understand what the user is experiencing? Here are two free options that will create a web upload with link: Screencast or Jing.
I have seen where a Shift key is "stuck", or a Shift Lock keyboard or accessiblity setting is in place. With Shift held down AutoCAD thinks you are trying to collect multiple grips, and makes each one you click red. Then you would have to release Shift to perform your next command.
Thanks 🙂
