Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and / or updated in the month of December?
Week One:
AutoCAD crashes when saving drawings to previous versions.
AutoCAD Mapping change to one direction
Crash when opening a drawing in AutoCAD
Crosshair does not display after launching AutoCAD
Design Center crashes AutoCAD 2015
How to get the object enabler for Bentley AutoPlant software for use in AutoCAD
Layout tabs shift incorrectly in AutoCAD
Model and Layout tab location in AutoCAD 2015 products
Old Map to define the Geographic Location for the sun location is missing
PC3 Plotterconfiguration list is not in alphabetical order
Texture alignment is not retained when object is copied or moved
Week Two:
AutoCAD crashes or freezes when running the LINETYPE command
AutoCAD icons blank for DWG and BAK file types
Drawing preview is not visible within the Select File dialog box when using AutoCAD
Error: “Unable to see objects in drawing”
How to autoload DLLs with AutoCAD
How to have continuous single-line and multi-line text editing in AutoCAD 2015
New subfolders do not index in Autodesk Content Service
Point cloud object snaps are offset from crosshair
Text missaligment in AutoCAD 2015 versions
The All Used Layers filter does not work in AutoCAD
What version of the program is running?
