In Revit and Inventor there is a command (decal) to be used to paste a picture or logo (for instance) to a 3D object.
Is there such command or similar to it in Autocad that can be used for the same purpose?
In AutoCAD, create a material with the image (as the render appearance) and then apply it to the solid. For curved surfaces, you could apply the material directly to the curved surface rather than to the solid. The UVW mapping also affects the appearance. AutoCAD and Revit have limited capabilites in these areas. For complete functionality, use 3ds Max.
