When I run the command Dataextraction, and after following the steps for extraction, I choose to play my data in an excel spreadsheet, only after checking spreadsheet, not export any data type, showing only the text "DeleteMe" in column A1 in the worksheet. I tested this command in AutoCad 2014 and AutoCadCivil in 2015, in which both exhibit the same problem.
That already happened commais someone?
We have solution for this?
I will be very grateful if anyone can help me, I need to extract data from several files, to present to the Board of the company where I work, and I see this to be the best option.
I await return.
Solved by olivier.eckmann. Go to Solution.
Solved by lesleys. Go to Solution.
I have never heard that AutoCAD writes "DeleteMe" into the exported data by itself, I guess it's something drawing specifix and so uploading the drawing so we can look into it + screenshots or >>>screencast<<< so we can see your settings in the DATAEXTRACTION wizard might be the best help currently.
- alfred -
Hi
I have had that happen in the past. What worked for me was save its as a CSV file instead of XLS. Open the CSV (should open in Excel) then just save as your spreadsheet.
Hope this helps
+1 with Lesleys
I've already had this "DeleteMe" when working with XLS direct. So I export to CSV and open it with Excel after.
Olivier
For any one plagued with this issue I believe I have found the culprit.
After several mock up efforts to duplicate the problem and deducting file size issues, networking issues, etc...I have found that using the apostrohe (") in the file name or any subfolder that is within the file was causing this "deleteme" issue.
When I removed the character, all worked well again.
Hope this helps someone.
