Hi
We mostly use LT we are still on 2012 but have subs and I will upgrade soon.
However we also have two copies of full blown Autocad currently 2014.
We have various toolbars that we have created, is there anyway (please say yes) to get the custom settings from Autocad LT 2012 to Autocad 2014 ??
(A very hopeful) Ross.
Solved by dgorsman. Go to Solution.
Yes. Where they are defined will determine how much work there is to do. The easy way would be if you created those toolbars in a separate, custom CUIx file that you partially load on top of the Enterprise or Main CUIx. In that case you only need a copy of the CUIx file and do the same. If you defined them in the ACAD.CUIx or other OOTB file, its best to transfer them to a fresh, blank CUIx first so this will be easier the next time.
