I'm looking to see if there is a way of using the publish function with our own custom plot stamp which is basically a rectangle with the words Working Copy and the date.
Currently we use a very old program (late 90's) called Runlisp to compile, from a lisp file, a script file on a set of drawings. The lisp file inserts our Working Copy stamp, plots the drawing, erases the stamp, purges & saves before opening the next drawing. This has worked for many years but has limitations on how many drawings we can plot at once & is no longer recognising spaces in folder/file names.
Is there a way to use Publish or maybe another way that offers the same functionality?
Tony
ACAD 2013
Solved by abubakars. Go to Solution.
Anthony,
I think the Free BatchInEditor as suggested above would make your task easier without lisp
you need to add the commands in the sequence mentioned below to get your job done
1. Add command "Block-Insert" to insert your plot stamp block
2. Add command "Plot-Layout" to plot the layout
3. Add command "block-Delete" to delete the plot stamp block just added for printing
4. Add command "Purge-All" to purge drawing
if the installation is the issue then I could help you sending the installed packed which you need to copy into your plugins folder under your AutoCAD roaming profile (hope you have access to that folder). or if possible to get it done by IT, you could install in any one of your system and share the installation package within your team to avoid multiple isntallation request to IT
AbubakarS
