AutoCAD 2013/2014/2015
0 Kudos
Post 1 of 14
Current layer problem - autocad 2013
1175 Views, 13 Replies
01-16-2013 08:12 AM
When I set a layer as current, every object or line I select in the drawing appear to be on that layer in the toolbar. Although in the properties toolbox, I see that the line I selected is still on the right layer.
I can't work in paperspace either, when I freeze a layer it freezes all objects. It seems like whenever I give a different layer to an object, it attributes to all object that same layer.
When I open the same drawing in acad 2008, everything is ok, the objects have the proper layers.
Is there a command for that or it's an acad 2013 problem?
Are you talking about PICKFIRST variable? if it's zero change it to 1
601 Kudos
Post 2 of 14
Re: Current layer problem - autocad 2013
01-16-2013 08:18 AM in reply to: Janiela
0 Kudos
Post 3 of 14
01-16-2013 09:06 AM in reply to: Patchy
Yesssss! It worked! Thank you!!!!
Active Contributor
1 Kudo
Post 4 of 14
01-22-2013 10:46 PM in reply to: Patchy
Worked like a charm.
Thank you
New Member
0 Kudos
Post 5 of 14
06-17-2013 12:17 PM in reply to: Patchy
Thank you! I was having the same problem!
474 Kudos
Post 6 of 14
06-17-2013 12:30 PM in reply to: Patchy
I'm thinking they should make PICKFIRST a hidden sysvar that is not saved between drawing sessions....
New Member
0 Kudos
Post 7 of 14
06-17-2013 12:52 PM in reply to: Patchy
Yes, it is the PICKFIRST that I was speaking about. I don't
know how this setting all of a sudden changed because I
didn't even know it existed. We installed AC13 a year ago.
I am not sure of the purpose of this setting but I don't
need it.
Donna Sylvanovich, ASLA
Thomas Klope Associates, Inc.
5150 El Camino Real
Building B, Suite 20
Los Altos, California 94022
Tel: 650-691-1000 Fax: 650-691-1014
donna@klope.com
CONFIDENTIALITY NOTICE: This electronic mail contains
confidential information belonging to the sender which may
be legally privileged. The information is intended only for
the use of the individuals or entities named above. If you
are NOT the intended recipient, you are hereby notified that
any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this electronic mail
is strictly prohibited. If you have received this
electronic mail in error, please notify us immediately.
446 Kudos
Post 8 of 14
06-17-2013 12:57 PM in reply to: rkmcswain
rkmcswain wrote:
Im thinking they should make PICKFIRST a hidden sysvar that is not saved between drawing sessions....
+1  ... or undefine PICKFIRST, so that the user must first intentionally redefine the variable in order to disable it.
Distinguished Mentor
81 Kudos
Post 9 of 14
06-17-2013 01:13 PM in reply to: nestly2
Can we put PICKADD on the list too? Why there is a button for that on the properties pallet is beyond me.
474 Kudos
Post 10 of 14
06-17-2013 02:39 PM in reply to: sthompson1021
I use PICKADD all the time, you just have to be aware of it and its current setting, or you'll get frustrated very quick.
