AutoCAD Forum
CUI Load
1 REPLY 1
GDolmanCSD
285 Views, 1 Reply
CUI Load
I recently had to install the VBA application from Autodesk, now during ACAD startup the CUI Load popup window appears and I cannot figure out how to shut this new"feature" off.
the last command I see on the command promp before the popup appears is
S::Startup-load_cuiload
this is the popup I am refering to.
http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCA...
The AUGI forum informs me it may be the ACADDOC.lsp file or the ACAD.lsp file.
I searched these and no command shows up.
Any Ideas?
1 REPLY 1
vlsheehan
in reply to: GDolmanCSD
Check to see if there is a file loading in the CUI or maybe APPLOAD.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
”Boost
