AutoCAD 2013/2014/2015
Distinguished Contributor
Karol-Or
Message 1 of 5 (182 Views)
CUI doesn't update
182 Views, 4 Replies
12-08-2012 02:54 PM
I added buttons to a toolbar, saved all CUI files with the only Save button available, pressed Apply, but the new buttons didn't appear.
*Expert Elite*
pendean
Message 2 of 5 (169 Views)
Re: CUI doesn't update
12-08-2012 08:29 PM in reply to: Karol-Or
which exact CUI file did you edit?
and do you have that toolbar turned on and undocked?
is it the correct toolbar?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Karol-Or
Message 3 of 5 (163 Views)
12-08-2012 10:07 PM in reply to: pendean
I found the reason but don't understand.
I added the buttons, yesterday, to the toolbar in the partial CUI. now i see a toolbar with the same name appear also in the main CUI file Acad.cuix.
I added the buttons to that toolbar and it updates.
So, i have, always, to add to the toolbar in the main CUI, and then use the transfer tab?
I must have transferd this toolbar to the main CUI, because i see it there, also, and i don't see toolbars from other partial CUI files, like the EXPRESS, in the main CUI.
In this case, i understand, if i transfered to the main CUI, i have to add to the toolbar in the main CUI, right?
And, if i want that my toolbar will have the same behaviour like other toolbars from partial CUI files, i have to remove it from the main CUI, right?
**Master
dmfrazier
Message 4 of 5 (145 Views)
12-10-2012 06:40 AM in reply to: Karol-Or
"So, i have, always, to add to the toolbar in the main CUI, and then use the transfer tab?"
It should not be necessary to transfer anything.  You should be able to create a toolbar in your custom CUI with the same name as a toolbar in the ACAD CUI.  (Although I would recommend using unique names, just to avoid the potential for confusion.)
I think the part you are missing is to modify your workspace and turn on your new toolbar (and maybe also turn off any toolbars that you don't need or want).  It shouldn't be necessary to remove anything from the ACAD CUI.
Valued Contributor
llorden4
Message 5 of 5 (125 Views)
12-11-2012 06:15 AM in reply to: Karol-Or
Are you trying to add buttons to an AutoCad menu?  I've experienced problems with that in the past.  I find the best results are to create a new menu and place all your desired commands toolbars in your new menu.  Some will call me crazy, but I've actually duplicated many of the AutoCad menu's in my own menu's and don't have any "out of the box" menu's loaded.  I've had no problems customizing as needed over the years, and upgrading to newer versions has been seamless so far.  Good luck.
Post to the Community
New Post
Need installation help?
