I thought I have done this in the past, but maybe not. I wanted to created a matchline for instance and then use the ctab variable in a field to reference the next or previous sheet. I was hoping it was as easy as ctab + 1, ctab -1, but I am unable to edit the expression. Thanks in advance for any help...
Solved by rkmcswain. Go to Solution.
Are your layouts named with numerals?
If so, here is an example of how: http://cadpanacea.com/node/364
You'll just use a system variable (CTAB) instead of the object data in that example.
I just tried it here and it works.
The link needs to be updated, found the solution here.
https://cadpanacea.com/wp/?p=1971
