AutoCAD Forum
Creating the size of an object
8 REPLIES 8
Message 1 of 9
an42drew
582 Views, 8 Replies
Hello there,
I am creating flat patterns of sheet metal parts and i would like cad to do some calculations for me.
For example when i am creating an object , be it a rectangle or simply a line , i dont want to have to work out my sizes on the calculator then input the size to create the object. I would like cad to do the sum for me by inputting my sum straight into the dimension of the object i am creating. E.g CLick rectangle, select a start point and type 1200-375+37+37+10+10, Then tabbing to do a similar thing for the width
The way i draw flat patterns is to start with the overall size then chop into that shape to create a finished pattern. I also have used Inventor and a software for cnc punching called Cadman. Both of these programs you can do this and what with Inventor also being a creation of autodesk i would have thought this could be done in cad as well.
Is there an add on or a simple command that will let me do this.
Any questions or if i am not explaining myself properly feel free to ask.
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: an42drew
You can use the transparent calculator 'cal within a command, but its not quite the same thing as Inventor.
Message 3 of 9
W2CAD
Or you could type:
(+(- 1200 375) 37 37 10 10)
Autodesk AutoCAD 2014 Certified Professional
Message 4 of 9
GrantsPirate
You can type (- 1200 375 (+ 37 37 10 10)) at the command line when it is asking for a length. A simple example would be (- 1200 375) or (+ 25 12 34) when dividing use a decimal place so it won't round off (/ 12 5.0)
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 5 of 9
an42drew
Thanks for your responses. I can use that format of equation for a line but cant get it to work for a rectangle where two dimensions are needed.
It wont let me tab to the next dimension.
Message 6 of 9
GrantsPirate
Rectangle, specify first corner point, (D)imensions, (+ xx xxx), (+ xyx xyy).
GrantsPirate
EXPERT ELITE MEMBER
Message 7 of 9
GrantsPirate
in reply to: GrantsPirate
I can't edit for some reason so I will clarify here. Rectangle specify first corner point (D)imensions (+ xx xxx) (+ xyx xyy)
GrantsPirate
EXPERT ELITE MEMBER
Message 8 of 9
an42drew
Thats works a treat thanks.
Its not as seemless as Inventor or the Cadman package i used to use, but it works.
Message 9 of 9
dgorsman
You can also assign constraints in AutoCAD (again, not as good as Inventor; its NOT Inventor, after all) then edit the constraints.
”Boost
