Hello there,
I am creating flat patterns of sheet metal parts and i would like cad to do some calculations for me.
For example when i am creating an object , be it a rectangle or simply a line , i dont want to have to work out my sizes on the calculator then input the size to create the object. I would like cad to do the sum for me by inputting my sum straight into the dimension of the object i am creating. E.g CLick rectangle, select a start point and type 1200-375+37+37+10+10, Then tabbing to do a similar thing for the width
The way i draw flat patterns is to start with the overall size then chop into that shape to create a finished pattern. I also have used Inventor and a software for cnc punching called Cadman. Both of these programs you can do this and what with Inventor also being a creation of autodesk i would have thought this could be done in cad as well.
Is there an add on or a simple command that will let me do this.
Any questions or if i am not explaining myself properly feel free to ask.
Solved by GrantsPirate. Go to Solution.
You can use the transparent calculator 'cal within a command, but its not quite the same thing as Inventor.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Thanks for your responses. I can use that format of equation for a line but cant get it to work for a rectangle where two dimensions are needed.
It wont let me tab to the next dimension.
GrantsPirate
GrantsPirate
Thats works a treat thanks.
Its not as seemless as Inventor or the Cadman package i used to use, but it works.
You can also assign constraints in AutoCAD (again, not as good as Inventor; its NOT Inventor, after all) then edit the constraints.
