AutoCAD 2013/2014/2015
New Member
0 Kudos
Post 1 of 3
Creating own scale on autocad
124 Views, 2 Replies
04-23-2013 07:19 AM
I am trying to set up a scale of a known distance on a photgraph that I have put in autocad. I know that this distance is 100mm, and have tried to work out how to mark this known distance, and then be able to work out the measurements of other dimensions in the photograph, including non-linear measurements. Is this possible?
Thanks.
*Expert Elite*
214 Kudos
Post 2 of 3
Re: Creating own scale on autocad
04-23-2013 07:30 AM in reply to: lo47
Using the Scale command, and the reference option (watch the command line) you can easily to this.
Scale, select, pick any point as a base point, R for reference, pick the two points you know are 100mm, now type in 100.
From there you can just use the DIST, MEASUREGEOM, or DIMENSION commands to pull other lengths.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
*Expert Elite*
127 Kudos
Post 3 of 3
04-24-2013 01:05 AM in reply to: lo47
Draw a line at a known direction and length that corresponds to something in your image.  Then insert the image in the drawing.  Now ALIGN the image to the line and say YES to scale objects.  It will now be scaled and oriented properly.
The ALIGN command is great anytime you bring something like an image or a scanned drawing in as a reference.
Dave.
Dave Hein, P.E.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
