I know how to edit atributes.
I even how that I can copy them and create one with new properties and then create a new block with those same attributes.
I don't know how to create one from scratch.
Could someone please direct me to the proper instructions?
Solved by ampster402. Go to Solution.
Thank you ampster.
I've been using AutoCAD for a long time but without some type of training from time to time to keep up with new features,
you learn what you need at the moment and end up pushing on.
These little commands get missed until I can find someone that can show me the way.
Radar
np, it is one of those commands you don't use often, at least when all the blocks have been created.
Add that to the other hard to remember - use once a yr - type commands
sdi
sysvdlg
convertpstyles
etc
