Solved by Alfred.NESWADBA. Go to Solution.
Solved by rkmcswain. Go to Solution.
does >>>that link<<< help?
HTH, - alfred -
When you are creating/editing the block, check on the appropriate boxes.
>> Don't suppose you know if this work for point styles for Civil 3D as well?
If you use a block in the Civil 3D point style then Civil 3D makes that "more annotative" than a block can be in AutoCAD.
E.g. a block in AutoCAD has to be assigned to the scales to be shown, Civil 3D makes that from alone.
Look to that image that shows the style-settings, use your block as symbol and set as size option "Use drawing scale" active:
HTH, - alfred -
