AutoCAD Forum
Creating Annotative Blocks
4 REPLIES 4
MatTheDrafter
3341 Views, 4 Replies
How does one make a block that is annotative, that change its scale based on the annotative scale being used? Still new to annotation and would like to make all our block annotative so I don’t have to keep changing out block sizes base on the scale of the drawing.
Tags (2)
4 REPLIES 4
does >>>that link<<< help?
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
rkmcswain
in reply to: MatTheDrafter
When you are creating/editing the block, check on the appropriate boxes.
MatTheDrafter
in reply to: rkmcswain
Don't suppose you know if this work for point styles for Civil 3D as well? I want to make point styles for Man holes that are annotative and believe they have to be blocks first.
If you use a block in the Civil 3D point style then Civil 3D makes that "more annotative" than a block can be in AutoCAD.
E.g. a block in AutoCAD has to be assigned to the scales to be shown, Civil 3D makes that from alone.
Look to that image that shows the style-settings, use your block as symbol and set as size option "Use drawing scale" active:
HTH, - alfred -
Alfred NESWADBA
”Boost
