I am trying to draw a ring shape for some equipment I am having made. I have drawn the orthografic views for the object but am having difficulty creating the donut-like shape and making an Isometric view of the object. Any help would be greatly appreciated
Solved by Patchy. Go to Solution.
Thank you for your response to my post. I understand how to draw isocircles, what I am trying to do is give it dimension to where is looks like a donut shape. In other words I want to give it that extruded look with rounded edges, make it look like a Torus shape.
Isometric sometines more difficult to draw than 3d.
I hand drawn an engine piston many years ago and when it come to draw recess for the connecting pin, all curves were faked in.
Nowaday use 3d is a lot easier.
You can draw 3d, slice it and copy the curves or move to 3d and moving forward
Hey that almost looks like what I want, but when I put the drawing on a layout can I make it so my orthographic drawings are flat(top view)?
Would I put the 3d drawing in a separate viewport?
this is what I am drawing, hope this clears up any questions
You can draw this with plain autocad using basic shapes (Box and torus)
and a few commands such as LOFT (for the weld)
Sweep (sweep a circle around a larger circle for the ring)
And a month from now, wow, yes you can do it.
Patchy,
If I had more thumbs I'd give you a thousand kudos, thanks!
And thanks for providing the steps to do it, this will help me out a lot when I assemble stuff in the future.
