AutoCAD Forum
Creating a dynamic 3d object...
4 REPLIES 4
REID7800
520 Views, 4 Replies
I have a 3d object that has no grips or points that you can manipulate... I would like to create an object that you can stretch/modify... can this be done?
_____
Reid B.
_____
Acad 2015
Architecture 2010
4 REPLIES 4
Alfred.NESWADBA
in reply to: REID7800
you have a 3D-solid alread reworked through some boolaen operations.
To select now the basic components you have to select the object, then <CTRL> and select the subobject ... and that can be modified by grips (as long as SOLIDHIST was enabled).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
REID7800
in reply to: Alfred.NESWADBA
I didn't know you could do that. thank you. I can't manipulate the object in a dynamic block (linear stretch). Is this possible?
_____
Reid B.
_____
Acad 2015
Architecture 2010
Alfred.NESWADBA
Sorry, no. The dynamic options are only 2D and don't include solid manuipulations.
- alfred -
Alfred NESWADBA
REID7800
I've made a program to convert 2d to 3d using the specs in paperspace (via lisp). I figured what I need to do. Thank you for your help
_____
Reid B.
_____
Acad 2015
Architecture 2010
”Boost
