I spent 4 hours this afternoon creating & customizing about 15 tool palettes. AutoCAD MEP 2014 w/ latest service pack. I opened tool palettes, right-clicked on the the title bar > New Palette... then renamed it. Copy/pasted buttons from other TPs & edited those buttons. Then I closed AutoCAD and reopened. They were gone, (not present in the 'customize palettes' command) nowhere to be found. No ATC files were created in my tool palette file locations either. Ive attached an image showing my Options, I have checked both directories, neither contain the ATC files. Does anybody have any suggestions? Or did AutoCAD just screw me out of 4 hours of my life?
I can recreate this scenario easily, every time I run AutoCAD, create a new TP, no ATC file gets created, upon restart TP is missing.
Dustin
Solved by dmfrazier. Go to Solution.
hello sir,
try to save your current setting to workspace....
pls look attachment.
hope this will help.
regards,
Virgilio Benedictos
Your issue sounds a lot like this one:
http://forums.autodesk.com/t5/AutoCAD-2013-2014/Palettes-not-staying-put/td-p/4796551
No solution yet, but there have been some suggestions, and Autodesk Support has now chimed in, so maybe soon?
