AutoCAD 2013/2014/2015
Active Member
0 Kudos
Post 1 of 7
Accepted Solution
Couple quick questions
417 Views, 6 Replies
10-12-2012 09:32 AM
Is there a way in the command line to select certain objects. For instance if there is a cirlce a line and a square can i just select the circle using the command line. When i try to save as an STL file i can't find it anywhere. Does surfsculpt not work? Everytime i use it it says it failed. Also when i make an ellipse is there anywhere to specify the X Y and Z lenghts?
Yes, either using _QSELECT or _FILTER (>>>details<<<) or e.g. LISP-ssget functionality, ... but it's not easy to select a specific circle if you have more then one and all have the same properties.
In that case you need at least the handle to that specific circle (or other object).
What does the command-line tell you while it's saving (and after that)?
Am I right that it does not say "it failed", it tells you more than just these 2 words, e.g. something like "Solid creation failed, no watertight volume detected.".
Let us know the exact message and upload the drawing with the objects you are working on.
An ellipse has no Z-length as it's a plane object, plane to the current UCS.
And when you create the object you are asked in the command-line for the points/angle. If you already have created that object look to the properties window (<Ctrl> <1>) to see what parameters the objects has and which one are modifyable.
- alfred -
>> I need to creat and ELLIPSOID with the major axis of 30 the minor axis of 20 and the width in the z dirction of 20
Create an ellipse with 30 length and 20 width and extrude it by 20, then use _REVOLVE. No need of any formula.
>> I have attached the picture. (SURFSCULPT)
That can't work with just one object
From the help:
      Trims and combines surfaces that bound a watertight area to create a solid.
>> Is there any way to find the density of the ellipsoid?
Most info that you can get about a solid is by command _MASSPROP
Sorry that I missunderstood that above.
>> is there any good tutorial series?
AutoCAD can do so much different things (and is used in many different branches) so I can't say "That tutorial is what you need". Search through www, you'll find a lot, take the ones fitting to your needs/jobs.
- alfred -
you have to define the revolve-axis (the centerline of the ellipse) and you have just to revolve 180° and not 360°.
- alfred -
*Expert Elite*
1,218 Kudos
Post 2 of 7
Re: Couple quick questions
10-13-2012 11:25 AM in reply to: acqualife
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Member
0 Kudos
Post 3 of 7
10-13-2012 11:41 AM in reply to: Alfred.NESWADBA
Thanks for your initial response! To follow up. I need to creat and ELLIPSOID with the major axis of 30 the minor axis of 20 and the width in the z dirction of 20. I will have to modify theses values for different geometeries. I know the equation x^2/a^2+y^2/b^2+z^2/c^2=1 is there any where to enter those values and get an output of a corresponding ellipsoid?
To follow up:
I clicked ctl 1 and saw this great window. Is there any way to find the density of the ellipsoid? I changed the thickness thinking maybe then i could create a water tight vlolume.
Thanks for your help. I have been looking all over the internet for solutions. I thought i would just post here so i could get help also. I was also wondering is there any good tutorial series? I've found serveral online but was wondering if there is a really good one out there?
THANKS
*Expert Elite*
1,218 Kudos
Post 4 of 7
10-13-2012 11:55 AM in reply to: acqualife
From the help:
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 5 of 7
10-13-2012 12:14 PM in reply to: Alfred.NESWADBA
Thank you so much for your help. I just have one more question
When i do that this is what i get (attached file)
This is the steps i am using.
ellipse
a
-5,0
10,0
5
0
180
extrude
all
30
revolve
all
360
So basicly i would like the ellipsoid to be at the length of the extrusion but to be an ellipsoid at that point. It seems it is extruding the half arc of the ellipse and then when i revolve it it is only revolving the length of the semi-minor axis in the z direction.
Thanks again!!
*Expert Elite*
1,218 Kudos
Post 6 of 7
10-13-2012 12:19 PM in reply to: acqualife
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 7 of 7
10-13-2012 12:47 PM in reply to: Alfred.NESWADBA
Thanks for your help. I think I'm going to need to try a different approach. I'm thinking im going to have to loft multiple ellipses to get what i want. I tried what you said but it wont let me revolve around the center line(which is the same as the major axis).  Maybe im doing it wrong. I have attached two pictures to try and explain better. I think even if i was able to revolve the other side it isn't going to turn out right. What i need is an ellipsoid with a major axis of 30- minor axis of 20- and it to go +15 in the z direction and -15 i the z direction. Thank you very much for you help i truely appreciate it!!
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
