Does anybody know of a program that will convert splines to polylines cleanly or has experienced the problem below?
We need polylines for waterjet cutting.
Using the polyline conversion in Autocad leaves us with highly complex jagged lines on the curves which crashes the waterjet machine.
We don't need a perfect conversion, just a very close smooth representation using arcs.
The main problem we have is with Sign Pro Flexi.
We use this program to convert clients spline artwork (usually supplied as EPS) to polylines
When we export to DXF to convert the splines to polylines, AutoCAD is unable to open the DXF and gives the error:
Table name missing on line 38.
Invalid or incomplete DXF input -- drawing discarded.
We don't know how to fix this. This problem didn't exist until we ungraded to a newer flexi program. The older one doesn't run on Windows 7.
I am running Flexi 8.0 v2
Autocad 2014
Most probably cause should be a bad conversion to DXF in the generating software, so it's no an Autocad's fault. Try support from Flexi vendor.
Gaston Nunez
What precision number did you use during the conversion? Did you use pedit and Spline the pline after the conversion?
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
