AutoCAD Forum
Converting Polylines Back to text
11 REPLIES 11
Message 1 of 12
adeebr
19461 Views, 11 Replies
I have received an dwg file from a client where all the text had been exploded. I need to convert these back to text. I was wondering if there was a way to do this. I have looked into some existing plugins such as raster design which uses OCR technology to recognize text. However to use that feature i need to insert a raster image which I i don't want to do. I was wondering if there is some way to detect text from polylines in the dwg file. Thanks.
11 REPLIES 11
Message 2 of 12
hwalker
in reply to: adeebr
Welcome to the Forums
Unfortunately there is no way for Autocad to recognise polylines as text.
Howard Walker
Left Handed and Proud
Message 3 of 12
pendean
in reply to: adeebr
Print it then run it through your scanner's OCR software.
Message 4 of 12
adeebr
in reply to: pendean
That's sort of what I am trying to do right now. However most online OCR softwares that I am finding aren't doing a very good job at recognizing the text. Here is what I have done so far:
- Take a screen capture and run the screen capture through an ocr software.
- Take a screen capture, edit the image in gimp to invert the image which would make it more readable by an ocr software
- JPGOUT command however that is pretty much the same as screen capture
- Plot to pdf but the pdf is not big enough and I can't zoom into the words
I have attached a screen capture of a word that I am trying to recognize.
Message 5 of 12
pendean
in reply to: adeebr
Print to paper, black letter on white paper, and run it through a scanner with OCR software. You need to get a quality OCR software (paid): I've never used a free one on the web that was worth much, especially if you are asking it to find dark blue letters on a black background.
BLACK letters on a WHITE background is the way to get good performance out of OCR software.
Or start typing: I suspect you've wasted more time finding a fix already?
Message 6 of 12
rkmcswain
in reply to: adeebr
I'm curious why you're looking for a technical solution for what seems to be a communication problem?
Why did your client explode the text?
Have you asked him for a version where the text is not exploded?
Surely your client wants to help you and not cause you to spend more time on his project.
R.K. McSwain     | CADpanacea | on twitter
Message 7 of 12
adeebr
in reply to: rkmcswain
Unforetunately I do not know why our client keeps sending files with exploded text. Since we've tried asking them but they didn't change. The thing we are separated from these CAD files by 2 degrees. Our client gets it from someone else.
Message 8 of 12
adeebr
Thank you. I am developing a program that uses OCR technology to pickup the exlploded text.
Message 9 of 12
sopcic2
in reply to: adeebr
I had something similar occur to me when importing from a PDF. *using AutoCAD LT 2018 * I was able to convert my broken text to text with Insert>Recognize SHX Text
Message 10 of 12
sharpl
in reply to: sopcic2
Can you please detail the steps? Thank you!
Tags (1)
Message 11 of 12
cadffm
in reply to: sharpl
When you start the PDFIMPORT you will see what that mean.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
- Sebastian -
Message 12 of 12
jomcardle
This worked really well!
”Boost
