I have received an dwg file from a client where all the text had been exploded. I need to convert these back to text. I was wondering if there was a way to do this. I have looked into some existing plugins such as raster design which uses OCR technology to recognize text. However to use that feature i need to insert a raster image which I i don't want to do. I was wondering if there is some way to detect text from polylines in the dwg file. Thanks.
Solved by sopcic2. Go to Solution.
Solved by pendean. Go to Solution.
Welcome to the Forums
Unfortunately there is no way for Autocad to recognise polylines as text.
Howard Walker
That's sort of what I am trying to do right now. However most online OCR softwares that I am finding aren't doing a very good job at recognizing the text. Here is what I have done so far:
- Take a screen capture and run the screen capture through an ocr software.
- Take a screen capture, edit the image in gimp to invert the image which would make it more readable by an ocr software
- JPGOUT command however that is pretty much the same as screen capture
- Plot to pdf but the pdf is not big enough and I can't zoom into the words
I have attached a screen capture of a word that I am trying to recognize.
Print to paper, black letter on white paper, and run it through a scanner with OCR software. You need to get a quality OCR software (paid): I've never used a free one on the web that was worth much, especially if you are asking it to find dark blue letters on a black background.
BLACK letters on a WHITE background is the way to get good performance out of OCR software.
Or start typing: I suspect you've wasted more time finding a fix already?
I'm curious why you're looking for a technical solution for what seems to be a communication problem?
Why did your client explode the text?
Have you asked him for a version where the text is not exploded?
Surely your client wants to help you and not cause you to spend more time on his project.
Unforetunately I do not know why our client keeps sending files with exploded text. Since we've tried asking them but they didn't change. The thing we are separated from these CAD files by 2 degrees. Our client gets it from someone else.
I had something similar occur to me when importing from a PDF. *using AutoCAD LT 2018 * I was able to convert my broken text to text with Insert>Recognize SHX Text
Can you please detail the steps? Thank you!
When you start the PDFIMPORT you will see what that mean.
