Hello all,
I have a query as to how I could automate the replacing of selected individual lines with predetermined sized rectangular blocks centered on the line at the angle and on the “0” layer . See attached file:
Would anyone have any ideas as to go about this. The rectangle need not necessarily be a polyline, 4 single lines would be sufficient. And whether the original line is or is not replaced is unimportant either.
Solved by hmsilva. Go to Solution.
If "individual" means that there is no automatic way to select them I would create a block containing the 0.5x0.03 rectangle and including a alignment parameter with the insertion point in the middle of the rectangle.
The resulting job would be then to insert that block, having object-snap "mid" active and show one baseline after the other (and the alignment parameter rotates automatically the block parallel to the line).
- alfred -
Hi s.holland.cmc,
in addition to what Alfred wrote, and for curiosity, do you have lots of rectangles to draw or just a few?
In your .pdf example I noticed that some rectangles were not 0.03x0.5, they were 0.03x1.0 or two with 0.03x0.5?
What is the criteria to draw a diferent rectangle?
If you have lots of rectangles to draw, is possible to write a lisp code, to perform this task for you.
Or I can write one, or post at the Visual LISP AutoLISP and General Customization Forum, there you will find some help to write the code.
Henrique
Sorry about that. I did forget that if I have a line shorter than or equal to 1.50” it needs a 0.03” x 0.5” rectangle. Anything larger than that needs a 0.03” x 1.0” rectangle. I can have over 1000 lines to convert per job. I’ve looked into writing a lisp file, but I can’t understand the code.
@s.holland.cmc wrote:Sorry about that. I did forget that if I have a line shorter than or equal to 1.50” it needs a 0.03” x 0.5” rectangle. Anything larger than that needs a 0.03” x 1.0” rectangle. I can have over 1000 lines to convert per job. I’ve looked into writing a lisp file, but I can’t understand the code.
One way:
(defun c:test (/ A B C D E I LN P01 P02 P03 P04 P1 P2 P3 P4 SS) (if (and (not (prompt "\nSelect the lines to draw rectangles: ")) (setq ss (ssget ":L" '((0 . "LINE")))) );; and (progn (setq i (sslength ss)) (while (not (minusp (setq i (1- i)))) (setq ln (entget (ssname ss i)) p1 (cdr (assoc 10 ln)) p2 (cdr (assoc 11 ln)) p3 (mapcar '(lambda (a b) (/ (+ a b) 2)) p1 p2) d (abs (distance p1 p2)) );; setq (if (<= d 1.5) (setq c -0.25 e 0.5) (setq c -0.5 e 1.0) );; if (setq p4 (polar p3 (angle p3 p1) c) p01 (polar p4 (+ (angle p1 p3) (* pi 0.5)) 0.015) p02 (polar p01 (angle p3 p1) e) p03 (polar p02 (- (angle p1 p3) (* pi 0.5)) 0.03) p04 (polar p03 (angle p1 p3) e) );; setq ;(entdel (ssname ss i));; if you want to delete the lines uncomment this line (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(90 . 4) '(70 . 1) (cons 10 P01) (cons 10 P02) (cons 10 P03) (cons 10 P04) );; list );; entmake );; while );; progn );; if (princ) );; test
hope that helps
Henrique
