Hello All,
I would like to connect CV curve control vertices to coincide with endpoints of constructionlines. But somehow it is not working like I would expect. the first time I grip edit the linear dimensional parameter it does something, not the right thing but goes the other direction. But the second time it doesn't go anywhere. So basically my question is if possible, how do I connect the control vertices to coincide endpoints of construction lines?
Any help is much appreciated,
Regards, Albert Gnodde
@Anonymous wrote:Hello All,
Do construction lines have end points?
Post your DWG.
Sorry for miscommunication, I meant that i converted regular line objects into construction geometry inside the block editor.
Here i have a picture where you can see the coincide points where the CV points of the cureve are laying on. Did draw the curve with the infer constrain ON.
Hi Albert,
Thanks for attaching the file. I took a look but I am not quite following how you would like this block to behave. I see the control vertices on the spline and the geometric constraints, but I don't see any dynamic block parameters. If you could provide more information about what the finished product is supposed to be, that would be helpful. A video explaining the behavior would be even better.
Try Screencast, which is free and also records audio: https://screencast.autodesk.com/
