AutoCAD 2013/2014/2015
drjohn
Message 11 of 42 (1,315 Views)
Re: confused about setting scale to paper size so will print out acurate to scal
09-18-2012 12:49 PM in reply to: Patchy
Patchy wrote:
Layout tab is the step to paper space.
Make a layer (e.g. VIEWPORTS so you can turn it off so it will not plot later)
Command MVIEW, make a view port.
When it's activated, either zoom xp or go to bottom of the screen and look for VP Scale, that is where you set scale.
Arrange your models and dimensioning them.
Get out of the viewport by using double clicks outside the viewport or use command Pspace.
Turn off the VIEWPORTS layer.
Draw your sheet size and Title block.
Plot your drawing.
... and lock the viewport. :smileyhappy:
Regard,
DJ
Active Contributor
bfrie1
Message 12 of 42 (1,312 Views)
09-18-2012 01:10 PM in reply to: drjohn
Thank you DJ When I make a viewport in layout tab it duplicates the drawing so one drawing(the same drawing) is a little offset from the other. What am I doing wrong? Thanks Bruce
Distinguished Contributor
Kazo
Message 13 of 42 (1,304 Views)
09-18-2012 01:52 PM in reply to: bfrie1
Your skills are rusty?  It seems you know nothing of AutoCAD at all.
So is layout the same as paper space which allows me to view what my drawing would look like on whatever size paper I chose?
Yes!
1.In layout won't let me use move to position desk? 2.do I dimension in layout or model space? 3.Not sure how in layout to determine scale? 4.do I determine scale in layout and when I go to plot?
1. You draw in model space or through viewport into model space.  When in paper space you cant edit model space entities.
2.  Either...but mostly in paper space using the dimension styles for different viewport scales.
3.  I think Patchy has explained that already now.
I think if i understand what youve written here ... you have created another layout??  You create your viewport within the confines of your drawing boundaries.  When you have created the viewport you should see your drawing in model space....and then zoom to scale...and lock viewport.
Read instructions in HELP. (F1)
Valued Contributor
its_cconner
Message 14 of 42 (1,299 Views)
09-18-2012 02:08 PM in reply to: bfrie1
Whenever you create a new viewport it will always start at the same basic view and it's up to you to rotate, zoom/pan and scale to your needs. Now if you copied the viewport it will keep the same scale and view you copied from and again you must rotate, pan/zoom and scale to your needs.
drjohn
Message 15 of 42 (1,296 Views)
09-18-2012 02:24 PM in reply to: bfrie1
Check this quickie setup out.
See the attachment
Ya just gotta take a class, bud.
DJ
Kazo
Message 16 of 42 (1,286 Views)
09-18-2012 02:55 PM in reply to: its_cconner
Oh right CConner..now I understand the question...
well done ..well answered !!:smileyhappy:
dgorsman
Message 17 of 42 (1,278 Views)
09-18-2012 03:24 PM in reply to: drjohn
Or, once you are at the office have another AutoCAD user walk you through it.  Some things are much better shown in person.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Active Contributor
bfrie1
Message 18 of 42 (1,279 Views)
09-18-2012 03:37 PM in reply to: dgorsman
Thank you, I agree I need to see this done in person but I don't know how I can find a user in my area? Any suggestions how to find someone in my area? Thanks, Bruce
Kazo
Message 19 of 42 (1,274 Views)
09-18-2012 03:48 PM in reply to: bfrie1
As previously suggested a class is what you need...you can get a series of half day classes...you may only need 3 or 4 that would take you though the fundamentals....wow...good luck with the new job...i wouldnt want to start a position with your limited amount of knowledge/skills.
JDMather
Message 20 of 42 (1,267 Views)
09-18-2012 04:33 PM in reply to: bfrie1
bfrie1 wrote:
I know a class would help a great deal but that isn't an option for me right now. I hope start a job using ACAD in a few weeks, my skills are rusty so I'm practicing on the 30 day demo release 2013. Through you help so far, I understand drawing in model space and using layout to prepare to plot. Would you please walk me through this? Thank you, Bruce
Unless I missed something - I still don't see where you have attached the file of what you have completed so far.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
