To All,
I have a sort of and "Odd Shape" cone that I am trying to create in AutoCAD as a solid entity.
The best way to describe this is that is is similar in size and shape to a "volcano" however it is, or will be just a "simple" cone with an odd contour.
My approach was to use something like the cone however, as soon as I tried altering the shape things didn't work the right way,
(I'll save that problem as another discussion). I also tried using the Loft command however it seems I am not getting the true shape. Someone suggested using or creating this with the Helix but I now think we are getting away from what I am trying to create here.
Any suggestions, or should I just keep plugging away until I get what I am looking for, (refer to attachments)?
I know this was part of the original post but for some reason the attachment did not show up:
Put a 3Dmesh in the volcano and sculp it to the shape you want then turn it to a solid.
Something like this:
hello sir,
based in your illustation, the best command is LOFT, try do some experiment on the settings, (Surface control at cross section)
hope it will help.
Virgilio E. Benedictos
I agree with Benedictos.Virgilio, the best command for this is probably the "loft" command using the "guidelines" option. I have attached a drawing showing a somewhat similar shape of your drawing using this method. The red arcs are what I used as the guidlines. Hopefully this helps.
Patchy, benedictos.virgilio, & Yorx57,
Thanks for all of your input! You all have at least pointed me in the right direction:
As suggested, I will experiment a little more since the Volcano looks more like a "Standard Shift Boot" but it's a point in the right direction. Thanks again!
