AutoCAD Forum
Command _viewedit Autocad 2015 Student Version
2 REPLIES 2
hidagamers
1355 Views, 2 Replies
Hello, I have a problem on Autocad 2015 Student Version. On layout, when I try to use command _viewedit. it's always failed with a words, "unable to perform requested action. this drawing was last edited with model documentation in a newer version of autocad". So anyone know how to fix it? Before I'm using other version like 2014/2013 is no problem.
Thank you
2 REPLIES 2
pendean
in reply to: hidagamers
Do you have SAVE set to 2012 or lower?
hidagamers
in reply to: pendean
Already get a solution.
there is tray in bottom right side, "PAPER", I click it to become "MODEL"
and I can edit the viewport.
but I still don't know why viewedit command is not working.
if I try in model space, acad said, "this command is not supported in model space."
but if I try in paper space, acad said, "unable to perform requested action. this drawing was last edited with model documentation in a newer version of autocad."
Frankly, I can't use viewedit shortcut and command
”Boost
