AutoCAD Forum
command line detailed step by step
6 REPLIES 6
rgold76
332 Views, 6 Replies
i toggled my command line so it would be my main prompt so i could copy paste this info into a script.  i forgot to write this down and now i can't remember how to toggle it back.  any help would be greatly appreciated.
6 REPLIES 6
JDMather
in reply to: rgold76
F2
Ctrl 9
not sure what you are after?
rgold76
in reply to: JDMather
that just turns the command line on and off.  i need the setting to toggle detailed command line on/off.  detailed like when you do a -plot that steps you through a command step by step.
Kent1Cooper
I'm not quite sure I understand what you're asking either, if the F2 key isn't the answer, but could it be the setting of the CMDECHO System Variable?
Kent Cooper, AIA
rgold76
in reply to: Kent1Cooper
its not those.  i'll try and give you and example
when i click express pulldown and select
-blocks
-replace blocks with another block
i don't get the window that pops up to select the block to replace.
i only get the command line with
Select the block to be replaced or[? = (select object)]:
the setting i'm looking for will toggle this and the selection boxes will open
nestly2
Change CMDDIA = 1 and while you're at it, make sure FILEDIA = 1
rgold76
in reply to: nestly2
thank you!
”Boost
