I'm loosing my crosshairs/cursor and commands don't work after I've made a circle into a viewport. Anyone else experience this problem?
ACAD 2015
Solved by christina.davis. Go to Solution.
That does work. However I was making sure that all text and info needed were not out of the circle. Toggeling back and forth can be a work around but I lose the boundaries of the circle. Why not fix the issue?
My text and info is all in model space. I do not annotate in layout.
To see the circle boundary I'd suggest drawing a circle in paper space that matches the viewport then use "chspace" to move it to model space. Put it on a no plot layer or erase it once you're done.
Hi cmiller,
I could not reproduce the lost crosshairs after converting a circle into a viewport.
Thanks 🙂
Hi cmiller,
Is working with hardware acceleration disabled still working for you?
Thanks 🙂
@christina.davis wrote:Hi cmiller,
Thanks 🙂
So far so good.
