AutoCAD Forum
circles, ucs
8 REPLIES 8
Message 1 of 9
bertbert
916 Views, 8 Replies
circles, ucs
hello,
I am facing a problem I previously met but for which i do not remember the solution.Circles i draw in a created ucs always appear as if they were in the basic world ucs.meaning:
the little blue snap point are not on the x, y axes but always on the world one.
How can i change this?
Thanks in advance!
BR
Bertbert
Tags (2)
8 REPLIES 8
Message 2 of 9
Patchy
in reply to: bertbert
I think you're talking about UCSFOLLOW
Message 3 of 9
bertbert
Hello and thank you for your reply,
The ucs i created is in use and all other elements follow the x and y coordinates which are horizontal and vertical as they should be. it is only the circles that cause problems. They are orientated like the world ucs no matter in which ucs i work in.
Message 4 of 9
Patchy
When I change UCSFOLLOW from 1 and 0
one setting would show full circle, the other one showed ellipse, I thought that is what you were asking.
Message 5 of 9
bertbert
in reply to: Patchy
no, unfortunately not. this doesn't change anything. i tried it.
it seems that everything is right and follows the ucs but the circles.
Message 6 of 9
nestly2
Can you post a sample drawing with at least one user defined UCS?
Message 7 of 9
bertbert
in reply to: nestly2
Message 8 of 9
nestly2
Ok, I understand the question now.  As far as I know, the grips will aways be aligned with the WCS... I don't think there's any solution.
Quadrant snaps should follow the UCS however, if that helps?
Message 9 of 9
bertbert
hi,
thank you!
strange, i had not noticed over the years. seems funny as the snap-points do not react to the actual ucs setting ...
wel ... thank you for your help!!!
Best regards,
bertbert
”Boost
