Hello, everyone, I'm now working with a Chinese company, when they send me their drawings, I found all the characters in the drawings are displayed in questioned mark, does anybody know how to fix this problem? I already change the system locale into Chineses, my windows system can display Chinese correctly now, but in Autocad it's still not working, I'm using Autocad 2013. Thanks
Solved by BeKirra. Go to Solution.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
You need to install a set of Chinese font (*.SHX).
It would be much easier if you ask them for a copy of Chinese font set which used by your drawing(s).
HTH
ask them to etransmit the dwg to you. Inside Acad, go to File > eTransmit
That will pull everything the dwg depends on into one location/file and then they can send all of that to you.
While opening the file they send to you from within the same location you first save it to (along with all the dependant files) will work then, it might be best to save any font files they include in that package down into your supported Acad search paths for future reference (Options > Files tab > and browse here for any paths you may need to research).
And don't be shy with those font files, share them with anybody else at your location that may be working on those files as well.
HTH
Thanks guys, I just got the shx files from them, it's a intecad.shx file, after I put this file in the fond file of AUTOCAD 2013, everything becomes correct, thank you so much~!
Scot-65
