I have hundreds of points and I need them all to be manhole symbols. Is there a way to make one of them a block and match the rest so they all are blocks and use the MH sybol? I have done it in the past, but I do not remember the specific command. Thanks!
I am in Civil 3D Imperial. I did this previously with making one of them a block or all of them and then matching characteristics. I think I might have exploded it at one point so they are all different blocks. I can't remember exactly what I did, but it wasn't using a lisp program. I also remember learning it from a youtube video, but now I can't find it. Frustrating when you find a solution, then lose it...
If they are Autocad points then convert them to Civil3d points, then just create a point sytle using the MH block as the symbol. If you need help ask in the Civil3D forum.
