AutoCAD 2013/2014/2015
1 Kudo
Post 1 of 3
changing block units
1117 Views, 2 Replies
12-03-2012 06:38 PM
i looked for this problem but it seems impossible, i have a dynamic block and it unit is unitless . i want to change it to mm .
if i use the command " bmake " the dynamic block will be lost because autocad will redefined the block and it can not redefined dynamic block.
also its a complicated block i can not make it again .
With _BMAKE you create a new block-definition. But as I understand your situation you already have a definition and you want to edit/modify that. In that case you should use _BEDIT (>>>details<<<) to get into the blockeditor, there you can set the block-units within the property-window (<CTRL> <1>).
- alfred -
1,218 Kudos
Post 2 of 3
Re: changing block units
12-03-2012 08:37 PM in reply to: mr-_-small
- alfred -
Alfred NESWADBA
1 Kudo
Post 3 of 3
12-04-2012 04:34 AM in reply to: mr-_-small
yaaaa you are the man .... thank you alot .:smileyvery-happy:
that exactly what i want .. you are awesome.
i search for this in this fourm but no such an answer like this ...  glad you here...
