AutoCAD Forum
changing background color in model sheet
5 REPLIES 5
James__S
14514 Views, 5 Replies
Hi
Where do i find the tools so i can change the background color on the model sheet.Also can the Grid lines be turned Off?
Cheers
5 REPLIES 5
M_Hensley
in reply to: James__S
To change colors select OPTIONS then the Display tab. Pick the Colors button and select from the list what you want to change.
To turn off the grid you can hit F7 or CTRL+G or pick the icon at the bottom of the screen.
James__S
in reply to: M_Hensley
Thank you kindly
robotashes5
By following these instructions all that happened was the bars at the top and bottom of the application turned white. The background to the drawing grid did NOT change white.
mr.pal
thank you so much.........
Sorry to have seen that quite late!
But you are not following the instructions exactly, you clicked on "Color scheme", not on "Colors", that's different.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
”Boost
