Does anyone know how to change the color of a selected Object? Say for example a Line that has been selected. On my system I have White Object lines. when I select say a Line the color changes to a color I have a hard time seeing. Doesn't help being color blind LoL...
Thank You For Any Help.
Solved by GrantsPirate. Go to Solution.
Solved by hgasty1001. Go to Solution.
Could you upload a screenshot to illustrate the problem? I don't quite understand your question. The more details you provie, the more accurate answers you will get.
It seems there is no way to change the highlight color of a picked entity, you can change anything else though, see selection in the options tabs. If you have trouble seeing colors, you can try a more high contrast settings, like white background and maybe light color scheme.
Gaston Nunez
Set
SELECTIONPREVIEW to 0
SELECTIONEFFECT to 0.
This is for 2015 only.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
