I would like to know if you can apply different line weight proporties to various viewports for the same default drawing?
lennore@outlook.com
lennore@shaw.ca
Solved by DaveFuller. Go to Solution.
Solved by lennore. Go to Solution.
Yes. In a layout, double click in the viewport in which you would like to assign (different linetype, color ...etc.). Open the Layer Properties Manager. Along the right side of the window, to the right of the assigned (properties) there are columns similar to the ones along the left side of the window. These columns have "VP" appended to the column title. These columns allow one to control the various properties of a layer in that viewport alone.
I hope that's what your question was.
