Using autocad 15, on the ribbin, on when editing there is a preview window.
I want to change this preview window to better represent the style.
For example if you have several styles with differ text or leader, the preview are the same. Useless.
so how do edit the preview window?
The ribbon pull-down preview of the different styles represents the font correctly on my machine. Not sure what you mean?
my preview is missing the Arrow, also my leaders are dashed and has leader points points.
The text say default text, I would like to change this.
The problem is that the ribbon is showing the same preview, and my style name are cut off, so I do not know which style to pick (except for the order).
see attached
I would like to create a custom preview,
I'm going to guess the arrowheads are not showing because they're too large. (ie larger than thier actual plotted size) ... same may also be true for the text height. I'm not sure about the truncated style names, but base on the red style names, I'll also guess it's because you've tweaked your Window (operating system) colors and scaling.
