I just transfered over to a new company and have my acad.pgp file. I come to find out that they load theirs from a server location which I am unable to alter. I have recieved permission to map my file, although I can't find where the configuration settings are to map it. I tried looking for the address in the 'options' area, but couldn't find it (tried 3 times). ANyone know where I can quickly change the location AutoCAD is looking for this file?
Solved by hgasty1001. Go to Solution.
Type in:
(findfile "acad.pgp")
and hit Enter, it will tell you where it is.
Since you can't delete company's .pgp it, put your own .pgp somewhere and add a new seach path to it.
If it loads your .PGP after the company's .pgp, yours will be used.
You need to ensure that Autocad load your pgp, to do so, you need to put the pgp file in a folder that can be found *before* Autocad find other pgp file. So copy your pgp to some folder, and add that folder to the support file path (command "options"->files tab->Support File Search Path), and move that entry to be listed *before* the current location of the pgp, as Patchy said, you can find the current location using (findfile "acad.pgp"). Now you need to "reinit" for Autocad to load the new pgp. The next time Autocad start, will find and load your pgp, no matter if other pgp files are in the support path.
Gaston Nunez
Yes, I had to change the order that the files were loaded. Thanks for highlighting that 😄 Very helpful indeed!
I follow your step to copy a path to my support path,and reinit and restart my Autocad also, but it doesnt work. It still cant use my own PGP. file commends. Any help on this ?
thanks alot
ACAD
As you can read above: Make sure your pgp is the first pgp acad will find.
For test: copy your pgp to a new local folder and add this path on top as 'searchpath for supportpathes" in Options/Files/
Restart Acad, it is the easy way without a way of mistakes.
Command: (findfile "acad.pgp")
Is it yours? Is it working?
ACAD.pgp
Make sure your Aliasname is only one time used in this pgp, or as the last of multiple times (not everyone know about these things good enough, the original is also not written well)
Hi, thanks for your reply.
I did follow the above mentioned steps, but as attached picture, the Auto cad still only can find the default file instead of the file I add on the top.
Any help? btw, i am using company pc, there are many restriction @ limitation access to do edit. is it any affect?
Thanks 🙂
Command: (alert(princ(apply 'strcat (mapcar'(lambda(s)(strcat"\n" s))(vl-directory-files "C:\\Users\\jingyao\\Desktop\\pgp" "*.pgp")))))
What message appears?
@xiaoxiao9299 - did you create/edit your .PGP file in Notepad? Do you have file extensions turned on in Windows? Perhaps *your* acad.pgp file is actually named "acad.pgp.txt".
Thanks for reply me.
ya i did check my file format is txt as attached , so how to credit it as pgp. file ? and how to turn on in windows for my file extension ?
on your options/support file search path, select you created location then select move up option. after that you can do (findfile "acad.pgp")
