I'm having trouble converting a 2D profile to a region for extruding. I'm a beginner so Apologies if I've missed somthing obvious.
Drawing attached. (Drawn in AutoCAD 14)
Edited by
Discussion_Admin
Solved by Alfred.NESWADBA. Go to Solution.
Just tried it, I can manage to extrude it, but not as a solid region. I want it solid like cube, and then i will subtract the circle in the middle, its ment to be one half of a plier.
Opps!! wrong drawing! attached correct drawing. 🙂
ps. can a mod please delete the original drawing uploaded please
I can't open it because I don't have newer autocad and true convert doesn't do Educational drawing.
If you can extrude and it doesn't give you solid, you have to look at the prompt line, there is option for Solid or Surface.
I've tried various things, still cant manage it 😕
I've saved it as a 07 drawing, let me know if it works.
I already have answered to your previous post, but it seems you (or an admin) has removed that.
Your start segment and end segment are self-intersecting, that makes it impossible to extrude the object.
- alfred -
I didnt see your previous post. Sorted it! cant believe I missed it. Thank you
Presspull is more forgiving that Extrude.
Tried it with that drawing? I didn't get it to run with PRESSPULL, what version did you use?
- alfred -
