AutoCAD Forum
Cant region a 2D object for Extruding
10 REPLIES 10
Message 1 of 11
mogaheda
1273 Views, 10 Replies
I'm having trouble converting a 2D profile to a region for extruding. I'm a beginner so Apologies if I've missed somthing obvious.
Drawing attached. (Drawn in AutoCAD 14)
Edited by
Discussion_Admin
10 REPLIES 10
Message 2 of 11
Patchy
in reply to: mogaheda
Use EXTRACT EDGES then Extrude
Message 3 of 11
mogaheda
in reply to: Patchy
Just tried it, I can manage to extrude it, but not as a solid region. I want it solid like cube, and then i will subtract the circle in the middle, its ment to be one half of a plier.
Message 4 of 11
Patchy
Pliers? Are you sure you posted the right drawing?
Message 5 of 11
mogaheda
in reply to: Patchy
Opps!! wrong drawing! attached correct drawing. 🙂
ps. can a mod please delete the original drawing uploaded please
Message 6 of 11
Patchy
I can't open it because I don't have newer autocad and true convert doesn't do Educational drawing.
If you can extrude and it doesn't give you solid, you have to look at the prompt line, there is option for Solid or Surface.
Message 7 of 11
mogaheda
in reply to: Patchy
I've tried various things, still cant manage it 😕
I've saved it as a 07 drawing, let me know if it works.
Message 8 of 11
Alfred.NESWADBA
I already have answered to your previous post, but it seems you (or an admin) has removed that.
Your start segment and end segment are self-intersecting, that makes it impossible to extrude the object.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 9 of 11
mogaheda
in reply to: Alfred.NESWADBA
I didnt see your previous post. Sorted it! cant believe I missed it. Thank you
Message 10 of 11
JDMather
Presspull is more forgiving that Extrude.
Message 11 of 11
Alfred.NESWADBA
in reply to: JDMather
Tried it with that drawing? I didn't get it to run with PRESSPULL, what version did you use?
- alfred -
Alfred NESWADBA
”Boost
