Having a hard time installing this. It gets down to around 26 out of 31 and the installation fails. Here is a little of the installation log file.
2014/8/18:21:49:35 Brittney-Jo FISHPIG PageOpen ProductSelectionDialog2
2014/8/18:21:49:44 Brittney-Jo FISHPIG PageOpen FullProgressDialog
2014/8/18:21:49:45 Brittney-Jo FISHPIG Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST...
2014/8/18:21:49:45 Brittney-Jo FISHPIG Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\BRITTN~1\AppData\Local\Temp\vcredist_x86_2012.log
2014/8/18:21:49:47 Brittney-Jo FISHPIG Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/18:21:49:47 Brittney-Jo FISHPIG Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST...
2014/8/18:21:49:47 Brittney-Jo FISHPIG Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\BRITTN~1\AppData\Local\Temp\vcredist_x64_2012.log
2014/8/18:21:49:48 Brittney-Jo FISHPIG Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/18:21:49:48 Brittney-Jo FISHPIG Download Skipped CM http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/CM.tar.l...
2014/8/18:21:49:48 Brittney-Jo FISHPIG Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2015" SETUP_PACKAGECODE={8CB42675-1900-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/18:21:50:14 Brittney-Jo FISHPIG Install Autodesk Material Library 2015 Succeeded
2014/8/18:21:50:14 Brittney-Jo FISHPIG Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/CMILB.ta...
2014/8/18:21:50:14 Brittney-Jo FISHPIG Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2015" SETUP_PACKAGECODE={8CB42675-1900-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/18:21:50:38 Brittney-Jo FISHPIG Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/8/18:21:50:39 Brittney-Jo FISHPIG Download Play CMILL http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/CMILL.ta...
2014/8/18:21:53:03 Brittney-Jo FISHPIG Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/CMILL.ta...
2014/8/18:21:53:03 Brittney-Jo FISHPIG Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
