I have AutoCAD MEP 2012 and the ability to purge text styles has stopped working. When I run purge no unused text styles are ever listed. However I can go into the Text Style dialog and delete them so I know they are unused. Anyway to fix this?
Is it possible to upload the problem file? you would get the quicker response from here rather than thinking of what could be the cause for this issue.
I'm sure this isn't a file problem. ALL files do this. This is an AutoCAD problem.
Here is a test file. I have 5 text styles in this file that do not show up in the unused list when I purge. However I can delete them in the text style dialog.
I bet you can purge them.
Have you tried using this command line to purge? If not try that.
Here is the commands hit enter after each line change.
-pu
All
No
Purging from the command line works. Thanks.
However it should show up in the purge dialog also, but doesn't. This is what I want fixed.
Like this. Notice other things show up to be purged but no text styles. I normally have the "Purge zero length..." checked but it is grayed out.
I dont know why it would purge out your text styles using command line and not dailog box. I never use the dialog box to purge. I use the command line for everything.
If I where you I would try an audit to make sure that it wasn't my system / file, and then try restating. I have noticed that if I keep autocad up and running for over a week, system variables like to go all haywire on me. With a close autocad and restart, it fixes a lot of problems that I ran across.
Hope that helps.
I can purge it out on my system using ACAD2015, so This is why i think it may be a system variable that is holding it up. I will take a look this weekend and hopefully i can find something for you.
Recently I have had problems purging apparently unused text styles, which I solved in at least two occasions by using command-line purge to get rid of regapps:
-purge
R
Y
and then hit "Y" for each regapp you want to delete. (Or alternatively if you follow the star with "N" it will delete them all at once, and it will still show you which regapps got deleted.) When you start a new drawing, are you loading a template (.dwt) file? Maybe it has regapps in it which point to otherwise unreferenced entries in the text style table; maybe you could figure it out by starting a new drawing and writing the drawing out as a dxf.
