I just spent 5 hours on my drawing, and now the drawing will not pan or zoom.
I have NO idea whats going on. I've tried turning off/on the hardware acceleration with no luck.
I've tried opening the file in Trueview, same issue. I tried opening it in DWGView Pro and it worked, but it does not hold the OLE references (excel spreadsheets).
Any ideas? Help!!
Solved by edwin.prakoso. Go to Solution.
MBUTTONPAN set to 1
It will sometimes change on its own. Check out some solutions here as well
http://forums.autodesk.com/t5/autocad-2010-2011-2012/mbuttonpan-problam/td-p/2950006
