Hi all,
i treied to hatch in autocad R2014 version getting fatel error and shutdown the software. any body can help me regarding this issue.
Regard's
Bijoy
welcome @forums.autodesk.com!
Does that happen in a new drawing base on an original AutoCAD template also?
If yes I guess there are some support paths wrong or defect hatch pattern files installed, in that case you might try to reset the AutoCAD profile (Windows start menu ==> section Autodesk/AutoCAD ==> Reset settings to default.
If that problem occors only with one specific drawing then run command _AUDIT to see if the database is ok, verify the border of the hatch (that it's clean) and if nothing helps upload that drawing with a marker or description so we know what area has to be hatched + what hatch pattern you use.
- alfred -
