I have a 3D element that has a curve and a bend. I need to flatten it so I can plot it out on a piece of 1/4" plywwod so when I put into place it will have the right cut. Is there a way to flatten it the element? See attached drawing.
Solved by JDMather. Go to Solution.
hi, command>flatten>select objects>all,
Please find attached. hope it helps
Flatshot?
Here is your Flat Pattern. (see attached dwg file)
I used Autodesk Inventor to create this Flat Pattern.
Is this what you needed?
AutoCAD does not have a function to create Flat Patterns, you need Autodesk Inventor or a 3rd party add-in.
I am trying to flatten these topo curves. See attachment. How can i do this in mac version?
Thank you
ariella
