AutoCAD Forum
can you flatten a 3d element
7 REPLIES 7
Message 1 of 8
440 Views, 7 Replies
I have a 3D element that has a curve and a bend. I need to flatten it so I can plot it out on a piece of 1/4" plywwod so when I put into place it will have the right cut.  Is there a way to flatten it the element? See attached drawing.
7 REPLIES 7
Message 2 of 8
3wood
Command FLATSHOT?
Message 3 of 8
ennujozlagam
hi, command>flatten>select objects>all,
Please find attached. hope it helps
Message 4 of 8
JDMather
Flatshot?
Here is your Flat Pattern.  (see attached dwg file)
Message 5 of 8
JDMather
I used Autodesk Inventor to create this Flat Pattern.
Is this what you needed?
Message 6 of 8
in reply to: JDMather
This is what I was looking for. I tried both "flatten and flat shot" commands but every time it would curve the long straight part, and I was concerned it would not plot correctly. I'm using AutoCad 2014, I'm assuming the commands are the same. Did you need to change the UCS?
Message 7 of 8
JDMather
AutoCAD does not have a function to create Flat Patterns, you need Autodesk Inventor or a 3rd party add-in.
Message 8 of 8
loftjm
I am trying to flatten these topo curves. See attachment. How can i do this in mac version?
Thank you
ariella
”Boost
